how to...speakers question
Old Jul 31, 2002 | 02:29 PM
steveng's Avatar
steveng
Default how to...speakers question
i just got my kappa today. to my surprise, there are no wires come with the package. so im wondering how i install these b!tches. please show me the instructions step by step
Old Jul 31, 2002 | 02:42 PM
b00gers's Avatar
b00gers
what dont you understand?
+ on woofer goes to + on xover for the woofer
same with tweets.
then there should be one set of +/- left, that does to the amp.
Old Jul 31, 2002 | 03:03 PM
99IntegraGS's Avatar
99IntegraGS
http://www.infinitysystems.com/carau...ct_support.asp
Old Jul 31, 2002 | 04:12 PM
LjN_728's Avatar
LjN_728
Have you ever installed components before? if not, you could be looking at a very long and boring day. haha
Old Jul 31, 2002 | 04:20 PM
steveng's Avatar
steveng
same with tweets.
i understand which goes to which, but i don't understand if i should use the existing wires for the woofers or not. some ppl told me yes, and some said no. so im confused.
Old Jul 31, 2002 | 04:52 PM
99IntegraGS
When you say existing wires, do you mean the ones from the factory?
I just installed a component set in my Integra. I ran the "existing wires" into the crossover, then with the two set of wires coming out the other side of the crossover I ran the pair for the woofers to the woofers, and the pair meant for the tweeters to the tweeters.
Old Jul 31, 2002 | 05:12 PM
steveng's Avatar
steveng
yes i meant factory wires. if this is how you did urs, then that's gonna be simple enough for me...hopefully
thank you
Old Aug 1, 2002 | 10:12 PM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
Your factory wires will go into the input of the crossover (+ and - corresponding). Then the tweeters will connect to the high pass output on the crossover. Run a set of wires from the low pass output on the crossover to the woofer. Viola. Easy as a drunken college gerl on spring break
Old Aug 1, 2002 | 11:05 PM
steveng's Avatar
steveng
thanx for the tips.
