how to...speakers question
i just got my kappa today. to my surprise, there are no wires come with the package. so im wondering how i install these b!tches. please show me the instructions step by step
what dont you understand?
+ on woofer goes to + on xover for the woofer
same with tweets.
then there should be one set of +/- left, that does to the amp.
same with tweets.
same with tweets.
same with tweets.
When you say existing wires, do you mean the ones from the factory?
I just installed a component set in my Integra. I ran the "existing wires" into the crossover, then with the two set of wires coming out the other side of the crossover I ran the pair for the woofers to the woofers, and the pair meant for the tweeters to the tweeters.
Registered Rota Dealer
Your factory wires will go into the input of the crossover (+ and - corresponding). Then the tweeters will connect to the high pass output on the crossover. Run a set of wires from the low pass output on the crossover to the woofer. Viola. Easy as a drunken college gerl on spring break
