Low Idle (Almost Stalls) 99 Civic EX
Old Jan 25, 2004 | 12:42 AM
PeckerWood504's Avatar
PeckerWood504
Default Low Idle (Almost Stalls) 99 Civic EX
My car starts fine but when it warms up it idles low "300 - 400 rpms". When i have my AC on it drops even lower and almost wants to stall but doesn't and it will keep doing that over and aver again. I have had a diagnostics computer hooked up to it and i get no codes.. My car is a 99 civic EX stock with 94,000 miles. Should i manually adjust the idle or could it be my O2 sensors or my Idle control valve.. If i manually adjust the timing and I have a bad ICV what would the result be and the same for the O2 sensors.. All plugs, wires, Dis cap, and rotor have been changed 2000 miles ago. The car runs fine other than at idle. And I also notice that if it sits at an idle too long it will overheat after time (15 mins or so) but comes down as soon as i give it a little gas.. Could that be a result from an idle that is too low or could it be my water pump?? I'm stumped and could use some help
Mtch (PeckerWood)
Old Jan 25, 2004 | 09:17 AM
qtiger's Avatar
qtiger
Manually adjust the idle a bit. If you aren't experiencing any other weirdness (large idle fluctuations, lopey idle) that's probably all it is.
Take care of that first and then worry about the overheating. It could be a result of a low idle... water pump isn't spinning quite as fast as it normally would be.
Tom Carson
CRX & Pre 92 Civic
5
Mar 31, 2003 06:26 PM
White[Pony]
Nov 14, 2002 10:17 PM
i want a civic
92+ Civic/EL & Del Sol
48
Sep 1, 2002 06:06 PM
Fujiwara Takumi
18
Jul 1, 2002 10:19 AM
jaje
News & Rumors Archives
17
Jun 27, 2002 03:16 AM
