Washer Fluid Problem
Old Jan 24, 2004 | 03:02 PM
SiHatchR6's Avatar
SiHatchR6
Default Washer Fluid Problem
Having trouble getting my wiper fluid to work. I checked all the fuses. They are all fine. I ran an air hose through the fluid tubes to see if anything was clogging it and it was fine no clogs. When I try to turn the wiper fluid on I can hear the motor but it just wont squirt any fluid out. Any suggestions as to what I else I can check? Any help would be great thanks.
Old Jan 24, 2004 | 05:28 PM
vassil3427's Avatar
vassil3427
Now did you try turning them on being disconnected from the squirters?
Old Jan 24, 2004 | 05:47 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
captain obvious says, "always check your actual tank for fluid" the pumps aren't hooked up at the bottom so if the fluid is below that point, you get no fluid!!!!
also check to see if your hose has a leak, or your squirters are clogged
:thumbup:
Old Jan 24, 2004 | 06:11 PM
Hondaman's Avatar
Hondaman
Black Pearl
Your pump may have lost it's "prime" too. Run some fluid through the pump manualy to make sure there is liquid in the pump.
Old Jun 2, 2007 | 06:05 PM
VTEC&MTX's Avatar
VTEC&MTX
I'm having similar issues with my washer fluid system. I checked the fuse in the set under the steering wheel - it's one fuse for the wiper blade motor and the fluid motor, and the blades work.
I used a 12v battery to power the washer fluid motor and it squirted the blue stuff with no problems.
Multimeter shows no voltage and resistance of 1 at the wiring harness that connects to motor when the system is activated. Are there any other fuses / relays i'm not aware of. Could this be the switch in the steering column, or does the wiper blade control module have anything to do with the fluid motor?
I'm not looking forward to jacking around with all the wiring and a multimeter if it comes to that...
jaje
News & Rumors Archives
31
Mar 14, 2003 10:02 AM
HLD_Civic
92+ Civic/EL & Del Sol
Nov 18, 2002 06:52 AM
Black2KGSR
9
Sep 22, 2002 10:38 AM
Accord1278
Accord
3
Aug 9, 2002 12:09 PM
dingusjt
2
Jul 24, 2002 05:57 PM
