Hard to push pedal after replacing clutch.
Old Jan 12, 2004 | 03:00 AM
bekylane's Avatar
bekylane
Default Hard to push pedal after replacing clutch.
Hi.
I just had my clutch and pressure plate replaced on a 98 LS. Used and exedy Daikin kit, wich is the same one the car had.
Also I got the clutch pedal adjusted to be at the same height as the brake pedal. (used to be 1 inch higher).
Now the clutch is harder to push than it was beafore, there is no other problem exept for this.
I have the following questions:
1) Is it normar for a clutch to have the pedal harder to push when new?
If not, do you think that it is harder due to the pedal adjustment or is it a problem with the Pressure plate?
2) What is the correct height for the clutch pedal on a new Integra?
3) Is there a break in period for new clutches? If so how many miles.
Thanks,
Rebecca L.
Old Jan 12, 2004 | 04:37 AM
Kai's Avatar
Kai
Rotorphile.
Well, the new pressure plate will probably be a fair bit tighter because it's new. If they flushed/bled the clutch hydrolics, that would tighten it a bit too.
Old Jan 12, 2004 | 03:25 PM
slickboy's Avatar
slickboy
ECHC junkee
Default Re: Hard to push pedal after replacing clutch.
Someone can correct me if I'm wrong, but I believe there is about a 300 mile break-in period, no freeway driving, losts of stop and go traffic, no stupid burnouts, major slipping of the clutch, etc. Just normal city driving under normal driving conditions. When Drumsy put an Exedy Organic in his gs-r, I'm pretty sure that was the suggested break-in period. I think he just drove around A LOT for a couple of days so the fun could start.:thumbup: :thumbup:
Old Jan 12, 2004 | 04:19 PM
XSrcing's Avatar
XSrcing
1. new clutches will be tighter because the fulcrum on the pressure plate with a new disc is different than the old one.
2. the clutch hight isnt a huge deal. put it somewhere comfortable, but make sure it will fully disengage.
3. yes. you should break in your clutch for 500-700 miles. just drive normal. that means no clutch dumps or hard shifting. but freeway driving wont hurt it at all.
Old Jan 13, 2004 | 03:29 AM
bekylane's Avatar
bekylane
Default Thanks, another question.
Thanks Guys!
I will miss the hard driving for a while .
Also I have the follwoing questions:
I read in the Haynes mannual that the clutch pedal must be 6.5" from the floor when adjusted.
1) If the pedal is adjusted 6.5 inch it would be 2 inches higher than the gas and brake pedals. Do all integras have the clutch pedal higher than the gas and brake?
2) Will adjusting the clutch pedal height affect the clutch trabel? A mechanic told me it does not matter the height of the pedal but I am not sure.
Thanks again.
PS: what is a clutch dumps
Old Jan 13, 2004 | 12:17 PM
XSrcing's Avatar
XSrcing
if the the clutch pedal hight was adjusted in the correct manner, it will have no affect on clutch travel.
a clutch dump is when you let the clutch out extremely fast.
Old Jan 14, 2004 | 01:52 AM
bekylane's Avatar
bekylane
Thanks guys! :thumbup:
