CV Boot
Old Jan 9, 2004 | 04:52 PM
ExiledinIN's Avatar
ExiledinIN
Default CV Boot
Once I hear clicking sounds on my CV joint, do I need to do anything special besides cleaning the grease out and replacing the boot? (91 Integra RS w/ left side CV boot needing to be replaced)
Old Jan 9, 2004 | 05:19 PM
Daniel's Avatar
Daniel
If you can afford it, I always recommend replacing the entire axle. Once CV joints bust, it's very easy for dirt and debris to get inside. With it being so difficult to remove, $80 at your local AutoZone can net you a new axle covered with a life-time limited warrenty.
Old Jan 9, 2004 | 05:24 PM
ExiledinIN's Avatar
ExiledinIN
Would the noise itself go away after I repack the bearing?
I'm still debating on keeping the teg, so I'm not so sure I want to do that yet. Plus it's cold as heck in the garage right now...
Old Jan 10, 2004 | 06:52 AM
JimBlake's Avatar
JimBlake
If the boot's torn & grease is leaking, OK. But after you start hearing the clicking noise, that usually means the joint has some damage. So repacking the bearing usually just muffles the noise & the damage gets worse.
Old Jan 10, 2004 | 08:39 AM
ExiledinIN's Avatar
ExiledinIN
So is it a new axle or both axle and/or CV joint?
Old Jan 10, 2004 | 10:41 AM
Daniel's Avatar
Daniel
An axles is comprised of the shaft and inboard and outboard CV joints. All you need to ask for is an axle.
