any pro/con for used stuffs??
some local guy is selling his amp and 2 10"subs for 420. He claimed that they have been used for a year, with receipts. I am wondering if i should get them instead of spending 700 on a brand new amp, 2 subs and wires. if you were me, which one would you be getting, considering the value and sound quality
ok here is the amp he is selling
Alpine MRV-T757(2 channel)
Max 750x1
75x2 rms cont.
150x2 rms cont 4ohm
240x1 rms cont
this is amp i wanna get
Alpine ClassD MRD-m500 (mono)
900x1 max
400x1 rms 2ohm
200x1 rms 4ohm
P.S either one will be powering 2 10" subs with 300w rms
Max 750x1
75x2 rms cont.
150x2 rms cont 4ohm
240x1 rms cont
900x1 max
400x1 rms 2ohm
200x1 rms 4ohm
If you are willing to wait a month or so, I can get you the Alpine MRD-M500 and two Type-R SWR-1021D 10" dual 2ohm woofers for cheap. The reason for the dual 2ohms is, you would wire them in series to get a 4ohm sub each, and parallel them to the amp to get a 2ohm load on the amp. Send me an IM or a PM
Originally posted by steveng
just curious why to wait a month ? i thought i need 4ohm instead of 2ohm?
Most amps run most efficiently at 2ohms. The alpine amp you wanted to get gives 400watts RMS @ 2ohms, but only 200watts RMS @ 4ohms. PM/IM me if you have any more questions. :thumbup:
Originally posted by Cashis EG8
I have to order them from Alpine and they take 4-6 weeks to ship me the stuff.
Having a final output of 4ohms would be good if you were using a 2 channel amp because then you could run it at 4ohm bridged (effectively a "2 ohm" load, but I won't get into that). Since the amp you are getting is a 1 channel mono amp, you can't bridge it. Therefore it runs most efficiently when shown a 2ohm load. Theres some website that explains all this in detail. Anybody know the site?
Max 750x1
75x2 rms cont.
150x2 rms cont 4ohm
240x1 rms cont
900x1 max
400x1 rms 2ohm
200x1 rms 4ohm
Max 750x1
75x2 rms cont.
150x2 rms cont 4ohm
240x1 rms cont
900x1 max
400x1 rms 2ohm
200x1 rms 4ohm
