any pro/con for used stuffs??
some local guy is selling his amp and 2 10"subs for 420. He claimed that they have been used for a year, with receipts. I am wondering if i should get them instead of spending 700 on a brand new amp, 2 subs and wires. if you were me, which one would you be getting, considering the value and sound quality
ok here is the amp he is selling Alpine MRV-T757(2 channel) Max 750x1 75x2 rms cont. 150x2 rms cont 4ohm 240x1 rms cont this is amp i wanna get Alpine ClassD MRD-m500 (mono) 900x1 max 400x1 rms 2ohm 200x1 rms 4ohm P.S either one will be powering 2 10" subs with 300w rms |
What subs are you getting with it?
if i decide to buy the m500 from the store, i will trade in my currect 10" for 2 10". They are the same subs, except that the cones are different and mine is not dual voice coil
ALpine type r |
If you are willing to wait a month or so, I can get you the Alpine MRD-M500 and two Type-R SWR-1021D 10" dual 2ohm woofers for cheap. The reason for the dual 2ohms is, you would wire them in series to get a 4ohm sub each, and parallel them to the amp to get a 2ohm load on the amp. Send me an IM or a PM :)
just curious why to wait a month ? i thought i need 4ohm instead of 2ohm?:confused:
used stuff...is well, used. you dont really know for sure how they were treated or used. or even hooked up correctly.
if you can afford it, get it new. |
Originally posted by steveng just curious why to wait a month ? i thought i need 4ohm instead of 2ohm?:confused: Most amps run most efficiently at 2ohms. The alpine amp you wanted to get gives 400watts RMS @ 2ohms, but only 200watts RMS @ 4ohms. PM/IM me if you have any more questions. :thumbup: |
Originally posted by Cashis EG8 I have to order them from Alpine and they take 4-6 weeks to ship me the stuff. Most amps run most efficiently at 2ohms. The alpine amp you wanted to get gives 400watts RMS @ 2ohms, but only 200watts RMS @ 4ohms. PM/IM me if you have any more questions. :thumbup: |
Having a final output of 4ohms would be good if you were using a 2 channel amp because then you could run it at 4ohm bridged (effectively a "2 ohm" load, but I won't get into that). Since the amp you are getting is a 1 channel mono amp, you can't bridge it. Therefore it runs most efficiently when shown a 2ohm load. Theres some website that explains all this in detail. Anybody know the site?
Re: any pro/con for used stuffs??
Originally posted by steveng some local guy is selling his amp and 2 10"subs for 420. He claimed that they have been used for a year, with receipts. I am wondering if i should get them instead of spending 700 on a brand new amp, 2 subs and wires. if you were me, which one would you be getting, considering the value and sound quality ok here is the amp he is selling Alpine MRV-T757(2 channel) Max 750x1 75x2 rms cont. 150x2 rms cont 4ohm 240x1 rms cont this is amp i wanna get Alpine ClassD MRD-m500 (mono) 900x1 max 400x1 rms 2ohm 200x1 rms 4ohm P.S either one will be powering 2 10" subs with 300w rms |
