Cant get crank pulley bolt off- 91 civic
Old Nov 25, 2003 | 02:48 PM
Toahk's Avatar
Toahk
Default Cant get crank pulley bolt off- 91 civic
Anyone have ideas on how to get the crank pulley bolt off, we have tried everything except a impact wrench. If you have any ideas it would help, this thing doesnt want to move at all.
Old Nov 25, 2003 | 02:49 PM
Snoopy's Avatar
Snoopy
been there done that
maybe an impact wrench?
Old Nov 26, 2003 | 08:33 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
Impact!
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Nov 26, 2003 | 08:37 AM
lingerbw's Avatar
lingerbw
Did you read my thread? My crank bolt story
Old Dec 1, 2003 | 09:47 PM
jinx-mitchell's Avatar
jinx-mitchell
The Comic Guy
Do you have a crank pulley tool?
Old Dec 2, 2003 | 05:41 AM
lingerbw's Avatar
lingerbw
Yup, here it is: thetoolwarehouse.net
You will need a 1/2" drive breaker bar to attach to that tool.
Old Dec 2, 2003 | 12:02 PM
firebane's Avatar
firebane
when I took my pulley off for my alternator and power steering the one on my original motor was a bitch to remove the bolt. An impact couldn't get it so we used the 1/2" breaker bar with a cheater bar and got it, then aftewards we just pulled the pulley off with out using the tool. And when we swapped the pulley over onto the new engine the same thing, didn't have to use a pulley tool and didn't even need a breaker bar, just used a impact wrench.
Old Dec 3, 2003 | 03:26 AM
lingerbw's Avatar
lingerbw
The "pulley tool" we're referring to is not a puller. It is a tool to hold the crank in place so you can try to break the bolt loose without turning the motor. (I used a 5 ft cheater pipe to break mine loose too :thumbup: ) You're absolutely right though. Once you break that bolt loose and remove it, the pulley just slides off because it's keyed, not pressed on.
Old Dec 3, 2003 | 09:40 AM
firebane's Avatar
firebane
couple of bolts in the back end and a big pry bar will hold it in place
Old Dec 6, 2003 | 07:46 AM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
take out the starter and shove a screwdriver down in the flywheel to jam it in place... get a BIG STRONG screwdriver.. then just loosen the pulley bolt.. you may have to re-do the timing tho after your all done... *torque it to spec*
