turbo problem
Old Oct 7, 2003 | 07:03 PM
jayk2k3's Avatar
jayk2k3
Default turbo problem
i installed my drag turbo on integra gsr. the car runs fine, but now after 1 hour of driving, i looss my idling and at 6,000 rpm i get a fuel cut off??????? im thinking it might be a ecu problem, cuz its a obd 2 type r ecu with a chip in a GSR. OR could it be a fuel problem or a cooling problem????
please help!!!![
Old Oct 7, 2003 | 07:58 PM
PHiZ's Avatar
PHiZ
BOOST GOD
yeah your shit is messed up good.
The ITR ecu won't controlt he secondary intake runner of the GSR IM.
Also, I'd say there is a 95% chance you got scammed on that being a chipped ecu. There are VERY few sources of chipped OBD2 hardware.
also, could you slowly, calmly, and with some semblance of grammar recount your problem's symptoms again, in depth.
-PHiZ
Old Oct 9, 2003 | 01:45 AM
yellow civic ex's Avatar
yellow civic ex
ghey slow d16 modder
if you get fuel cut around 6k rpm then it's possible that the oil pressure isn't as high as it should be and the ecu wants you to baby the car.
Old Oct 14, 2003 | 07:03 PM
jayk2k3's Avatar
jayk2k3
thanks every one!!!! It turned out to be the ecu.
