Clutch/trans issue please help
Old Mar 24, 2012 | 08:50 PM
travisc88's Avatar
travisc88
Default Clutch/trans issue please help
I bought a used 02 civic sir as a commuter, used car dealer said it needed new syncros, problem is...
When i push clutch slightly move shifter into any gear it makes a funny noise whining/gear noise, also if in neutral position it will make same sound if i push clutch to floor, if i let off a bit it goes away,
so it goes into gear fine, let the clutch out car moves like normal, but when i go to shift to any other gear its like clutch isnt working, like shifting without clutch, very stiff, gearing down is the same, lots of pressure in clutch feel, if i drive slowly put clutch in and rev car it makes a scraping sound and clutch acts funny,
question is, do i need new trans or new clutching system?
Thanks for the help i tried to be as clear as i could, any questions just ask
Old Mar 26, 2012 | 04:40 PM
travisc88's Avatar
travisc88
anyone??????????????
Old Mar 27, 2012 | 08:50 AM
janepaul's Avatar
janepaul
having the similar issue help me with the best solution guys please...
