Jackson Racing Help!! Running Rich!-
Old Jul 12, 2002 | 04:11 PM
civicon19s's Avatar
civicon19s
Default Jackson Racing Help!! Running Rich!-
Hey, i finally got my jackson'd B16 running.... the problem is that its ideling at about 4k rmp AND my a/f ration guage is pegged at rich! If tryed setting my fuel pressure regulator ect and it doesnt seem to make much of a change. Also when i adjust the distrubutor to change the timing, it makes just a marginal difference! What can i do?? I Need help NOW! You can call collect at 770-258-4507!!!! ASAP
Old Jul 12, 2002 | 05:20 PM
one11racing's Avatar
one11racing
In my own world
what car is this in?
Old Jul 12, 2002 | 07:35 PM
qtiger's Avatar
qtiger
What fuel control are you using and do you have aftermarket injectors?
Old Jul 12, 2002 | 09:00 PM
civicon19s's Avatar
civicon19s
Well, ive got it running BUT with the MAP sensor disconnected...this way, it idles at a mere 2500 whereas when it is plugged in (vacume line of sensor) it idles at nearly 4000!! Also, how am i supposed to know how far to retard the timing??
Old Jul 13, 2002 | 10:57 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
do you have that rubber thing under the map sensor? i also know some kits give you this thing put under you map sensor and it causes the kit to sit much higher.
if you look on the stick of motor pics in the forum look at nutsacks motor picture, and you'll see what i'm talking about for the map sensor.
when we pulled my friends map sensor off, we accidently left the rubber piece off, and it burnt half a tank full of gas in one day.
also we had played with the tps sensor (overbord tb), and it wasn't set back to spec. I dunno how much the map sensor effects the idle...
Project EVA - The Track Package
Project EVA
civic1988
Engine Swaps, Tech & Tuning
6
Jan 25, 2004 11:28 AM
civicon19s
6
Jul 22, 2002 06:49 PM
civicon19s
Jun 30, 2002 08:10 AM
