Master Cylinder/Brake Booster compatibility???
Old Aug 17, 2003 | 09:26 PM
PHiZ's Avatar
PHiZ
BOOST GOD
The car wasn't there, cause it doesn't drive. The check valve was impossible to miss, it mounted on the firewall and was on the only vaccuum line going from the manifold to the booster.
You may not have it, my 99 didn't, he has a 5th gen...
-PHiZ
Old Aug 17, 2003 | 09:33 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
I didn't notice it :dunno: But I'll take a closer look.
Old Aug 19, 2003 | 09:35 AM
egzivic's Avatar
egzivic
There are several issues to consider when changing even a stock brake booster. There is a push rod adjustment that is difficult to do in the car that is mostly the cause of your draging issues. If you look on behind the brake pedal you will notice a 12 point nut. That nut locks the push rod adjustment. With the booster removed measure from the base of the booster to the clevis (bracket that connects the push rod to the pedal assembly). It should measure 116 +/- .5 mm. If not loosen the 12 point nut and adjust the push rod. If the push rod is too far (the measurement is less than 116mm) what would happen is the brakes would be applied constantly. The shorter the measurement the more the brakes would be applied. Like I said it is not a fun adjustment in the car, but it can be done if you have a 12 point box 14mm (I think, maybe 12mm) wrench that you are willing to cut a notch in to make it a 12 point line wrench. The other issue maybe the bleding process. Make sure to bench bleed the master cylinder before it is installed. It can be messy, but it could save you from issues in the long run. If you need to know how to bench bleed the master cylinder PM me as this thread is getting long.
The brake booster/master cylinder adjustment procedure should be available in an manual as well. The measurement I provided was for an Integra booster/master cylinder, but the process and adjustment is the same for a Civic.
Old Aug 19, 2003 | 10:37 AM
PHiZ's Avatar
PHiZ
BOOST GOD
Hey, good info thanks. I've been bench bleeding the MCs i've been doing.
-PHiZ
Old Aug 19, 2003 | 10:41 AM
white_n_slow
it's my D in a B
wow. long post. That may be my problem, I never adjusted the pushrod on the teg booster I put on. I can measure it up against the civic one and match the pushrod stroke... I think I'll tackle this one off the car, though. thanks for the info.
Old Aug 20, 2003 | 05:33 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
indeed great info on the adjustment.
as for master cylinder and brake boosters.
i've got a 1" gsr i'm gonna put in.
just scared to bend and double flare it.
any one got extra brake lines for me to practice on?
Project EVA - The Track Package
Project EVA
Old Aug 20, 2003 | 08:37 PM
white_n_slow
it's my D in a B
I actually have the whole line from the gs-r that goes from that fitting in the MC on the left (the wierd one that doesn't match w/ the civic MC) to the prop valve. I'll check it for fitment, and if it fits well, I'll use it, but If not, I'll practice on half and give you the other half to practice on.
Old Aug 20, 2003 | 08:54 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
yeah the line won't fit at all.
i think it runs all the way to the front left into that huge abs thing...
either way let me know.
i need lines to practice on.
Project EVA
