Swap Question
Old Jul 24, 2003 | 10:26 AM
Spitz's Avatar
Spitz
Default Swap Question
I want to swap in either a b16a or b18c1 jdm engine into my 2000 civic ex. The only thing is i don't have any garage room(in college) to do it, so i really can't do it myself. So i was wondering what a good price for everything would be at a shop engine,install, new mounts etc. thanks in advance.
Old Jul 25, 2003 | 04:31 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Install is usually aroung $1000 give or take.
Old Jul 27, 2003 | 12:06 AM
Spitz's Avatar
Spitz
anyone know of any decent shops in wi or northern il
Old Jul 27, 2003 | 04:21 PM
drift's Avatar
drift
Flaccid Member
most shops should do it for $600-800. anything higher, and they're either taking too long, or charging too much per hour.
Old Aug 16, 2003 | 12:39 AM
PHiZ's Avatar
PHiZ
BOOST GOD
b18c1 or b16B, ONLY. You won't be happy with anything else.
-PHiZ
Old Aug 25, 2003 | 01:22 PM
mishima_beef's Avatar
mishima_beef
whats the difference between a b16a and a b16b and also why wont he be happy with a b16a?
Old Aug 25, 2003 | 04:41 PM
Snoopy's Avatar
Snoopy
been there done that
b16a is a torqueless wonder. b16b is basically a de-stroked b18c. its more of a jdm blingness engine more than anything else.
Old Aug 25, 2003 | 04:45 PM
mishima_beef
de stroked?
sorry to ask so much but ur gonna have to take it easy with me
Old Sep 21, 2003 | 06:15 PM
scottsi's Avatar
scottsi
i hope you have about 4500 - 5500 thousand dollars laying around because thats what its probably going to cost you to get a jdm gsr and the mounts plus have the shop do it, also theyre probably going to try and find other things wrong.
Old Sep 21, 2003 | 06:39 PM
Kai's Avatar
Kai
Rotorphile.
de stroked?
It has a different crank and rods, so it displaces less then the B18C the block was designed for.
(In Verb case)
Stroke: to make the stroke longer to displace more, ie the piston travels farther up and down.
de-Stroke:to make the stroke shorter to displace less, ie the piston travels less up and down.
Bore: to make the cylinder diameter wider to displace more.
There is no opposite of Bore, you can't make the tube smaller (short of resleeving.)
