VAFC pressure signal help and VAFC settings you ppl have! HELP
Old Jul 23, 2003 | 09:58 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
Default VAFC pressure signal help and VAFC settings you ppl have! HELP
Okay do i need to hook up the Pressure Signal IN and OUT wires on my mini-me swap? PM6 ECU.. i have the clip from the z6 head and its 2 wires: Red w/white stripe, Green w/white stripe, which one is which? also would i really need the pressure hooked up considering my ECU doesn't have that option?
Also i need to see someones settings for the fuel Hvt and Lvt Wide and Narrow throttle... i found one from a prelude but non of their settings had +'s it. IE - Lo cam - 4000rpm / -7% , not 1 setting on Wide or Narrow/ Lo or Hi settings has +'s in it, is that right? i have a d16z6 head and everything else is from an 88 crx si engine. PLEASE HELP
