Which turbo set-up?
Old Jul 20, 2003 | 05:06 PM
imlachg1's Avatar
imlachg1
Default Which turbo set-up?
I just bought a 92 hatch with a legit ls/vtec. She is built from the bottom up. She has low compression just begging to be feed some boost. From the money I saved selling my 00 coupe I have enough to buy some forced induction. The question I have is what kinda setup should. Is there a kit out there for such an engine? Just for your knowledge this engine was built buy Independent Honda in Fort Wayne, and was done the right way. Let me know what I should do. Thanks you guys are great.
Old Jul 20, 2003 | 11:06 PM
SSCivic's Avatar
SSCivic
Swolen Member
Look up my old posts on turbo setups and turbo kits. There's a wealth of information there. The bottom line of what i got out of it is this:
If you KNOW your shit about turbo setups, then just build your own setup ground up.
If you want the most power for your setup, get a custom built kit by a performance shop tuned to perfection.
If you want a basic turbo starter kit setup that will still put down 300whp, then go with a turbo kit, such as the Rev Hard kit, sa it does cater to hybrid swaps and motors. They have a setup for a B18B and B18C in a civic, so you should be straight with Rev Hard. That's what i'd reccomend.
