Engine code -- Map Sensor
Old Jul 19, 2003 | 03:29 PM
93 Sol's Avatar
93 Sol
Default Engine code -- Map Sensor
i have a 93 del sol si and installed a turbo on it. the turbo has been on since 2001 and now i am having problems with the map sensor. i have already replaced the sensor once but still have the error code light up. does anyone have any ideas on what the problem may be? thanks.
Old Jul 20, 2003 | 04:27 PM
Kai's Avatar
Kai
Rotorphile.
The turbo is causing the problem. Honda MAP sensors were not really designed to operate with positive pressure in the manifold. There are a few companies that sell check valves for this reason.
Old Jul 20, 2003 | 09:34 PM
yellow civic ex's Avatar
yellow civic ex
ghey slow d16 modder
im assuming that you were using a map sensor check valve before, since you've had the turbo on for a year, right??? if not, it's not very healthy for the car, cause the ecu doesn't know what to make of the +pressure. other than that, i've thrown a few codes since, but i think it's because a vacuum line let out some pressure or something, cause nothing really bad happens cept the car stalls....i just start it back up again and it's fine. also, to reset the light, just remove the negative battery cable and your ecu is reset and the light will go off. good luck!
Old Jul 20, 2003 | 10:59 PM
TheRooster's Avatar
TheRooster
Former Senior Member
Get a missing link if you're not going to change the ecm out at anytime. the plastic check valve octupus is a hokey setup.
If you change out the ecm, get a Bosch or GM 3-bar sensor. More than you'll ever need.
Old Jul 21, 2003 | 06:34 AM
93 Sol's Avatar
93 Sol
what's a 'missing link'?
Old Jul 21, 2003 | 07:41 AM
yellow civic ex
a missing link is just a piece of metal that goes between the map sensor and throttle body and prevents it from reading + pressure.
Old Jul 24, 2003 | 06:31 AM
93 Sol's Avatar
93 Sol
thanks, the missing link took care of my problem.
Old Jul 24, 2003 | 09:43 AM
s1ngle's Avatar
s1ngle
clutch slipping boost
where do you get a missing link?
Old Jul 24, 2003 | 12:23 PM
93 Sol's Avatar
93 Sol
this web site has them for $10 less than the company 'synapse'. some performance shops in your area may have them as well.
http://www.group5motorsport.com/cgi-...SE-MissingLink
