Question JDM or USDM Engines
Old Jul 16, 2003 | 10:14 AM
Johnny B's Avatar
Johnny B
Snap, Crackle, Pop....
Default Question JDM or USDM Engines
I heard all kinds of stuff....I don't know what's up with it....
Like the car won't pass emissions....Right?...Why not?
I heard that in JDM engines they are ran on higher octain in Japan and if you run them on 91 they will create a ping....Is this true?
I can't even remember all the stuff I've heard to write it out....Can someone please shed some light?
JDM engines are so cheap and easy to get compaired to finding a USDM....
Thanks
Old Jul 16, 2003 | 12:22 PM
v4lu3s's Avatar
v4lu3s
run some searches...there will be lots of viewpoints on it all.
91 or 93 octane is fine. i run it on my h22a's all the time and never have they pinged...nor have they failed emissions either.
Old Jul 16, 2003 | 08:13 PM
Johnny B's Avatar
Johnny B
And it was a JDM H22 engine?
Anyone with other info would help.........I've searched my ass off and came up with really not much......
I will be getting smogged tested in a month and then not for 2 years.........I also will be moving an a year to a no emissions state...(or they don't test the car annualy)
Thanks
Scott
Old Jul 17, 2003 | 11:32 AM
TheRooster's Avatar
TheRooster
Former Senior Member
As far as getting it smogged, it isn't a problem so long as you can prove that the engine you put in is functionally identical to the engine you removed. You couldn't smog an OBD=II car with an OBD-I engine. You could however smog an OBD-I car with an OBD-II engine because its newer. Regardless though, never admit to a full engine swap. There's lots more rules concerning that, than if say... you just swapped the block, because yours was cracked right? Obviously though if you put an H22 into a Civic or Integra though, it wouldn't matter... they'd consider it a full engine swap.
Best thing to do is check out the rules in your area. I know most states have pretty easy to find regulations.
