Bellowing smoke
Old Jul 1, 2003 | 02:31 PM
firebane's Avatar
firebane
Default Bellowing smoke
What would cause a engine to bellow out blue smoke like mad at higher rpms? Rings going or exhaust ports?
Old Jul 1, 2003 | 03:31 PM
crxb16er's Avatar
crxb16er
oil leakage somewhere, valve seals, rings, but oil is more blackish bluish can be a fuel problem, badly set air/fuel ratio, injector problem, .....
Old Jul 1, 2003 | 03:43 PM
firebane's Avatar
firebane
I took my plugs out and holes 1, 2, and 4 looked find but #3 had major oil deposits on it. So its probably a ring or valve seal.
Old Jul 1, 2003 | 05:09 PM
matt j's Avatar
matt j
midwest corn killer
check your valve cover gasket and spark plug grommets, usually when there is oil on the plug its the grommets, start with that and see what happens, thats the easiest to start with
Old Jul 4, 2003 | 04:27 PM
MikeR's Avatar
MikeR
he's right it is either a valve and or ring prob. a comp. test or a leakdown test would tell
