Just brought my first Integra...help this newbie :)
Old Jun 26, 2003 | 07:38 AM
noyintegra's Avatar
noyintegra
Default Just brought my first Integra...help this newbie :)
Ok I got a 94 RS, from a 1 owner. Got 116k on it right now. Car runs smooth even at 110mph She said she had Acura changed the timing belt at 69K. Got new AC compressor on 2 years ago. Its an automatic.
So what should I do next to make sure its in top running condition? What Oil should I used? When should I have the timing belt changed again & what should I replace while having it changed.
Thanks in advance for all your help. I'm mechanically incline
Old Jun 26, 2003 | 09:30 AM
JimBlake's Avatar
JimBlake
Look in the owner's manual for maintenance intervals. Maybe I can remember some of them...
Air filter every 30k?
Measure/adjust the valve lash every 30k. Inspect the timing belt each time since you're staring right at it when you adjust valves.
Change timing belt 90k. Are you REALLY sure she did it at 69k? Timing belt drives the waterpump so that's a good excuse to replace that while you have it apart.
Flush & change the brake fluid and the antifreeze every 2 years.
