Valve spring and ret. install
Old Jul 7, 2002 | 08:26 AM
ChillOutWayne's Avatar
ChillOutWayne
Default Valve spring and ret. install
im sure this subject is covered somewhere on here, but i searched and found nothing...im planning on buying skunk2 racing springs, tit retainers and stage 2 cams for my 94 GSR soon...i was wondering how difficult the install would be for the springs and ret, exc. cams...is it neccessary to take it to a maching shop, or is this possible with garage tools, also anything else i should know before diving into this? thanx in advance
Old Jul 7, 2002 | 01:10 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
You mainly need a spring compressor that will fit down in the head, as you can swap out all those components without removing the head from the engine, as long as you have a way to keep the valves up in place [compressed air or nylon rope]. Other than that, it's pretty straight forward after you remove the cams and the springs are staring you in the face.
-Harry
AIM: NDcissive
Old Jul 7, 2002 | 02:04 PM
TheRooster's Avatar
TheRooster
Former Senior Member
Its way easy if you have the head off, and make a special little tool for it. After trying for two hours to get one on, we made fashioned a little tube with an 1"x1/2" notch in the bottom and slid that down over stem onto the retainer. Then we used a normal spring compressor (looks like a big c-clamp) and the other 15 took about 20 minutes.
Old Jul 8, 2002 | 04:50 AM
ChillOutWayne
thanx boys
94civicEX
Automotive News & Rumors
Aug 19, 2014 09:40 AM
prostreetonline
Do It Yourself
Jun 25, 2004 10:43 PM
prostreetonline
92+ Civic/EL & Del Sol
5
Jun 23, 2004 11:12 AM
