General Swap Questions
Old Jun 3, 2003 | 09:13 AM
DC294GSR's Avatar
DC294GSR
How did I get here?
Default General Swap Questions
OK i just picked up a 98 EX, and eventually i would like to do a swap in it. I was just curious..say i want to do a B16 swap.. do i have to get the 2nd gen B16 with the hydro trans or can i get the 1st gen with the cable trans. Cause if I had to get the hydro trans then i would just spend the extra $ and get a H22.
Old Jun 3, 2003 | 06:33 PM
jlicrx's Avatar
jlicrx
you need the hydro trans
Old Jun 3, 2003 | 06:38 PM
DC294GSR's Avatar
DC294GSR
How did I get here?
i hear theres a way you can do it with the Cable trans. if you relocate the clutch master cylinder.. i dont know if theres more involved, or if its not worth the trouble or what. Anyone heard?
Old Jun 4, 2003 | 07:12 AM
DC294GSR's Avatar
DC294GSR
How did I get here?
here this thing:
http://app1.hybridgarage.com/store/h...o=002-01-EGBCC
Old Jun 13, 2003 | 09:49 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
What's up? You have more issues than just clutch type with your swap. Your best bet is to get the 2nd gen hydro clutch B16A. There is a conversion harness that basically uses your clutch's slave clyinder to move the cable mechanism (the link posted above). I've never used one, but they seem to work and you need a special upper mount to locate the upper tranny mount. The kit in the link above would work with an EG ('92-'95 Civic) but I don't think it will with an EK (different upper tranny mounts) so that's pretty much a bust anyway.
Another issue your going to have is the wiring. First gen B16A's will have a pre-OBD wiring harness. Your '98 is OBD II. No JDM engine is going to have the proper sensors (specifically the crank position sensor but I believe there are others) to allow you to use an OBD II ECU. You'll will most likely need a conversion harness and an OBD I B16A ECU (P30 I think) or a OBD I SOHC VTEC ECU (P28) that is rechipped with the B16A program. Another choice is the B16A2 from a '99+ Si. If you use the Si's engine wiring harness/ECU that should work. Will be pricey, but you'll have at best a 4 year old engine as opposed to a 13 year old 1st gen cable B16A. Seeya.
