Piston Rings?
Old Apr 17, 2003 | 08:25 PM
ColinT's Avatar
ColinT
Default Piston Rings?
I belive I have burned the piston rings out of two of my cylinders. Now my question is I have a 1st gen B16a and are the piston rings the same as the USDM B16's? Thanks in advance for your response.
Thanks, ColinT
Old Apr 19, 2003 | 10:26 AM
likaciv's Avatar
likaciv
Pretty Much its a Civic
Just a ? how do you know you burned the rings??
Old Apr 19, 2003 | 12:22 PM
qtiger's Avatar
qtiger
Um...yes? Shouldn't be any different.
Old Apr 20, 2003 | 08:32 AM
ColinT's Avatar
ColinT
well it runs on about what sounds to be 2 cylinders and the spark plugs are totally covered in oil. Im not 100% on the piston rind theory just preparing for the worse. Going to crack it open on Monday.
Thanks for your input.
Colin T.
Old Apr 21, 2003 | 04:24 AM
Kai's Avatar
Kai
Rotorphile.
Default Re: Piston Rings?
Yes. You might want to rebuild the engine for good measure though, even just replace it. Longblocks go for around $500.
Old Apr 21, 2003 | 04:35 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Colin T.
Why crack it open? Why not just do a compression test first to figure out if it's your rings or your valve seals?
Takes like 10 - 15 min to do a compression test... JMO
Old Apr 21, 2003 | 03:04 PM
likaciv's Avatar
likaciv
A compression test will just give you compression numbers, but a leakdown test will give you the location of your loss of psi's, my car came up with 180, 180, 145, 175. I replaced the headgasket and am not burning oil , and the plugs are clean, i think its the valves, im praying its the valves, a leakdowntest will show the true culprit though
Old Apr 21, 2003 | 09:52 PM
ColinT's Avatar
ColinT
By cracking it open I mean taking it to the shop and doing all the proper test. Well going to get to the nitty gritty tommorow will keep you in know. Thanks for your input.
ColinT
Old Apr 22, 2003 | 12:01 PM
likaciv's Avatar
likaciv
BTW to all who care i did a leakdown test on my motor and the number 3 piston rings are leaking. Time for some ITR action!!
