cam or n2o?
Old Mar 28, 2003 | 10:39 AM
Jeice's Avatar
Jeice
One Rad Dude
The way the ZEX nitrous kit works:
ZEX kit I have is a dry nitrous kit, meaning it sprays from a nozzle, into your Intake, unlike wet kits, which spray into the fuel injectors. It has a little computer box on it, that is programmed to spray nitrous at WOT. You wire the box up to your Throttle Positioning Sensor, the sensor that tells your car how much gas to give it in conjunction with the amount of force your putting on the pedal. The voltage of the TPS goes up as you get on the gas. When the line reads like 4.2 or so volts, the nitrous solenoid 'clicks' and begins spraying, most cars TPS sensor at WOT are above 4.2 volts (4.4/4.6). When you let off the gas it stops spraying.
You have a switch inside that turns on the Nitrous Management unit, the little computer that comes with the kit, when you arm the nitrous, its ready to spray as soon as you floor it. When you shift gears, you have to let off the gas to shift (well unless you redneck power shift it with the gas to the floor), which cuts the nitrous, - if the nitrous kept spraying youd get alot of air, and no fuel, lean motor = Detonation which = BOOOOM.
Old Mar 28, 2003 | 12:00 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
ok by you saying what would happen if it didn't stop i'm not so sure if i want Nitrous anymore what could cause the throttle to stay open when you let off the gas? or i should say what would cause it to go BOOM?
Old Mar 28, 2003 | 12:28 PM
hlhiii's Avatar
hlhiii
actually dry kits use the fuel injectors for the extra fuel when using nitrous. wet kits have a fuel solenoid along with a n2o solenoid and the two come together at a "y" fitting that sprays nitrous and fuel. both spray into the intake before the throttle body.
Old Mar 28, 2003 | 12:44 PM
preylude99's Avatar
preylude99
Is there any possible way the kit could malfunction and keep spraying when you arent at WOT causing your motor to blow up?
Old Mar 28, 2003 | 01:00 PM
Jeice's Avatar
Jeice
One Rad Dude
not really unless your gas pedal gets stuck :P
Old May 25, 2003 | 10:02 PM
goatnipples2002's Avatar
goatnipples2002
So jeice I can get 20 hp from an AEM cam gear? I don't have any mods except a short ram. Were you saying 20hp because j-speed had a sc.
Old May 26, 2003 | 12:03 PM
Jeice's Avatar
Jeice
One Rad Dude
20 hp from a Cam profiled for his SC, and cam gear, and dyno tuning.. yes.
Old May 26, 2003 | 12:31 PM
hlhiii's Avatar
hlhiii
that's aiming a little high. he's on a stock bottom end and head. maybe 20 with a p/p head plus the cam and sprocket. then have the car dyno tuned. cams work in conjunction with the rest of the motor. just dropping in a nice cam doesn't=big h/p.
Old May 28, 2003 | 04:15 PM
forum95's Avatar
forum95
I'm Cooler than You
What are your mods?? List your mods and maybe we can help you out a bit more.. Maybe its starving for fuel...
Screw the nitrous, you want somethings thats always there...
Old May 28, 2003 | 05:14 PM
hlhiii's Avatar
hlhiii
my nitrous is always there. that's 1 statement always heard. the next is you have to fill the bottle. blah, blah, blah. bottom line is N2O is an awesome power adder that has its pluses and minuses just like every other power adder. anyhow, cams are great. i put CTR cams in my b16. but the n2o i installed is BY FAR my best mod yet. and it's been in the car for a couple years.
