Wiring harness
Old Jun 26, 2002 | 01:57 PM
likaciv's Avatar
likaciv
Pretty Much its a Civic
Default Wiring harness
What king of harnesses am i going to need to put a 99 b16a2 into a 94 civic ex?
Old Jun 26, 2002 | 02:11 PM
sympl_RS's Avatar
sympl_RS
Default Re: Wiring harness
Just to add to the previous question, can you buy pre-modified wiring harnesses for certain swap applications? For example, I have a 1998 civic Ex with a manual tranny. If I wanted to swap in a b18C can I buy an aftermarket harness with all the modifications already done and simply plug it in to the ECU and engine?
Old Jun 26, 2002 | 02:22 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
It all depends on which engine you had in the car before you did the swap. I am swapping a '97 B18C1 into a '95 civic DX and I could not buy a harness that would just plug into my ECU because my stock harness did not have VTEC, knock sensor, IAB or VTEC oil pressure sensor. I have to run wires from the B18C1 engine harness to the ECU.
You can get premodified harnesses I'm sure, but it would be a serious pain in the a$$ to replace the harness from the ECU through the firewall.
Brian Wong (bwsf@hotmail.com) can hook you up with just about any harness you need.
Hope it helps.
Old Jun 26, 2002 | 05:55 PM
v4lu3s's Avatar
v4lu3s
Plkace Racing will make harnesses for you for $350 or so...
why not just use the civic ex harness? or even better if you want expensive and VERY easy buy a del sol vtec harness??
Dimi
4
Sep 4, 2003 09:17 PM
DakarM
Aug 21, 2003 07:21 PM
CivOnDubs
Sep 10, 2002 04:39 PM
