whitish crystally stuff on spark plugs
Old Jun 25, 2002 | 07:44 AM
AwwsChwA's Avatar
AwwsChwA
Default whitish crystally stuff on spark plugs
ok...all 4 plugs look the same. Nice and clean, no burning or pitting, but there's a very fine whitish-grey crust evenly covering each electrode. I looked it up, apparently that crust can form in *lean-running engines*, and in general a film of white or grey over the spark plugs is normal. Anyone have an opinion?
Old Jun 25, 2002 | 10:21 AM
dubcac's Avatar
dubcac
I
White specks or crust on the electrods means you are running lean/detonating. Are you running advanced timing?
Old Jun 26, 2002 | 10:13 AM
maxrpm's Avatar
maxrpm
Default what is the symptom of this
my spark plugs was new and after three days of driving they are covered in a black carbon deposit on all four. I also advanced and retard my cams. so, is this a symptom of my car running running or rich?
Old Jun 26, 2002 | 02:41 PM
undrgrndhaqer's Avatar
undrgrndhaqer
Mr. EG
if you have thick dark build up on the spark plug than that can mean either your running rich or you have alot of carbon build up in the block.
Also, how would you fix a running rich problem? I am running really rich on my 95 gsr in my 92 civic. It runs well, but is running very rich and has lots of backfire(including flames). I have contemplated to just get an adjustable fuel pressure regulator, but is there a cheaper solution?
Old Jun 26, 2002 | 05:18 PM
maxrpm's Avatar
maxrpm
what kind of mods do you have. YOu can adjust your distributor i think advance it a little. Or give it a tune up.
My block was rebuilt with new internals and it had all this build up about three days later.
Old Jun 26, 2002 | 07:21 PM
AwwsChwA's Avatar
AwwsChwA
I think my timing is actually pulled back just a bit. and no, it's not white speks on my spark plugs, its a very even, very thin coat of white-ish stuff.
What are ways to make my fuel mix richer? I mean...its computer controlled (91 crx si). How could I make it run more rich to see if the spark plugs look different after a few hundred miles? thanks
Old Jun 26, 2002 | 08:18 PM
dubcac's Avatar
dubcac
I
Well you can back off your timing a few degrees, or get an adjustable FPR and bump the pressure up a few PSI.
jdblack1's Avatar
jdblack1
If it's really lean then try a colder plug.
If it's really rich, I guess try a hotter plug to get a better burn.
AcuraFanatic
Apr 4, 2006 08:31 AM
wayne99integra
2
Apr 24, 2004 06:19 AM
madlow
Engine Swaps, Tech & Tuning
2
Sep 9, 2002 08:44 PM
