b16 assembly questions.
Old Mar 18, 2003 | 09:22 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
Default b16 assembly questions.
I'm putting my b16 back together this week. It is a 1st gen, but could I get a manual from a 94-95 delsol with the b16? I just need to know like torq settings and squish clearances on my bearings. Also have some kind of wiring diagram so I can figure out how the hell to put this thing back the way it was.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Mar 18, 2003 | 10:11 AM
rev's Avatar
rev
Oil clearance should be .0009-.0017 on the mains and .0013-.0020 on the rods. Torque the mains to 18# then 58#. Torque rods to 23# and the heads to 49# with an A2 or 62# with an A3 motor in steps. Damper bolt goes to 130#
Old Mar 19, 2003 | 11:11 AM
Import-Tooner
skoooooie!
Thanks!.
SKOOIE!!!
Old Mar 20, 2003 | 10:53 AM
-KangaRod-'s Avatar
-KangaRod-
Captain
I'd recommend looser clearances on the bearings, even as high as 3 thousandths. You'll free up more power as the clearances get looser, but you'll loose long term reliability
