quick ? about rear disc conversion
Old Mar 16, 2003 | 01:02 PM
vtec94civic's Avatar
vtec94civic
Default quick ? about rear disc conversion
i just got a 95 teg rear trailing arms w/ disc and ebrake cables and all, also, lower control arms, and rear sway bar, i wanna put it on my 94 civic coupe,
question is, do i need master cylinder or booster or proportional valve thing from teg??
can i use the stuff on my ex or would it be better to use the stuff off the teg?
i can get everything, but it looks like the teg M/C will not work.
i know this stuff is posted a lot, i just need a quick answer, nothing long a drawn out.
thanx
Old Mar 16, 2003 | 02:38 PM
b18hatch95's Avatar
b18hatch95
I put a 97 GSR rear in my 95 hatch about 6 mo ago. Everything bolted right up without a hitch. I'm using the stock master cylinder and prop valve. So far everything is has been working like a champ. After I finish my engine swap, I plan on installing the ABS computer, and harness . I think I'll need to put a different prop valve in then. For your rear disc upgrade, try in with the stock master cylinder and proportioning valve first.
