Nordskog Electronic Gauge Sender
I just got my nordskog A/F & boost gauges & sender for my teg from summit racing.
The gauges have instructions on where to connect which wires which seems simple enough, but the boost gauge sender just came in a lil box and doesnt have instructions.
Have any of you guys installed a nordskog boost gauge & sending unit, and have a copy of the instructions or can provide me with info on how to install it?
thanks
thanks
It should be pretty straight forward. Use a vaccum source that's located on your intake manifold to go to the sender. I noticed you have a GS-R, I teed my vaccum source from the behind of the intake manifold, sorta small but it works.
yea, thanks. i called nordskog the other day before i saw ur reply and it actually is pretty easy.
once thats in, now i can finally get my JRSC in (in my garage for 4 months due to time constraint problems and needing to get some parts together that were needed first ie..fuel pump gauges etc.)
spanky
Dec 3, 2005 10:05 PM
flipped cracka
Jan 5, 2004 09:02 AM
