For those considering LS/VTEC...
Old Mar 4, 2003 | 03:12 PM
DC294GSR's Avatar
DC294GSR
How did I get here?
Default For those considering LS/VTEC...
look what i found on GBC today.. i dont know if its any good, but seems interesting.
http://www.groupbuycenter.com/buy.aspx?id=8752
For those of you who arent registered..
Well, here she is. This our VTEC Conversion Kit. A very easy and
sanitary way to add a VTEC head to a non VTEC block. Uses filtered oil
for supply. Also has AN fitting for the head ( the correct metric thread
) so there is no stripping threads. All you need is to get a line made
whatever length you need! It also has a port that can be used or a
filtered turbo oil supply or pressure gauge sensor. Accepts the stock
filter. Installs in less than 10 minutes. No drilling or cutting
required. This is a very simple install and is a must for LS/VTEC or CR-VTEC
engines or for anyone with a turbo!!!
$114.50 Shipped
