lagging while accelerating
Old Mar 14, 2003 | 09:17 PM
XSrcing's Avatar
XSrcing
i'm curious as to why your running a modded ecu on a stock car...???
you are probably running so pig rich that it isnt even funny.
Old Mar 17, 2003 | 06:21 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
if i understand you right, i've had the same problem. i have an auto, and it would be stuck in neutral (while driving normally) until it caught. i would just have to wait until it actually caught to do anything, otherwise it would just rev and rev. it was my tranny (the gears were stripped because my fan wasn't turning on because my thermostat was busted. i had to get a new tranny (why i didn't just convert to manual while doing it, i'll never know....or yeah, g-parents paid for it) and it took care of it.
Old Mar 18, 2003 | 08:29 AM
wxt's Avatar
wxt
Innercity
Default Re: ^BUMP^
Originally posted by Jen
I spoke to the Honda mechanic who does my car mods...
he told me that the ECU, although modified, isn't to blame: rather, the 98 Civic trannys are known to be faulty.
Anyone else with a 98 have problems like mine?
I'm trying to weigh the pros & cons of going in to do a swap...
i have the same problem on my 95 civicn ex 5speed.....the only mod i have a an intake so that wouldn't cause the problem couse i had that problem before the intake....i though it might be either the fuel system problem or the ignition problem.....couse it feels like either there is not enough fuel coming in or like the car is running on 3 cylinders when i press the gas....if i press the gas very lightly no problem but if i press is moderatly it starts lagging, i'm assuming its ignition related......do u guys think changing spart plug wires will do anything? or is there anyway to check if the ignition system running correctly?
Old Mar 18, 2003 | 09:30 PM
sQwiReL bOi's Avatar
sQwiReL bOi
ya i have the same problem on my 97 gsr. but its manual. it feels like a 2-step in my car bein activated... witout the sound. like the spark juss stops and suddenly the spark kicks in and i get power like turbo. ive changed spark plugs and fuel filter. next im ganna try the spark plug wires. some1 told me it mite be my clutch slippin. =\
