guide me! b-series engine specs
Old Mar 2, 2003 | 08:46 AM
incublinkus's Avatar
incublinkus
JDM Fan Boy
Default guide me! b-series engine specs
alright guys here is the deal...tell me if this is feasable (sp?). I want a 2 liter B-series motor in my civic...end of story. I will get a 2 liter motor. I DO NOT want a CRVtec...I am not dealing with a frankenstein motor that was never meant to turn power in the first place.
So basically that leaves me with boring out a a B18C to 84mm and having it sleeved to get my 2 liter motor. Is their anything else I can do? Could I bore out a B16A to 2 liter? I plan on having my block resleeved and everything. what is the difference block wise between the B16 and B18? What crankshaft is better? Would a B16 bored to 84mm only be a 1.8 liter engine? Could I safely bore it bigger? Whats the rod/stroke of B16A? B18C?
I am asking all this because I could get a B16A block cheaper then a B18C...plus B16A heads and manifolds are just a little better cause the head flows better and the manifold doesn't have the secondary butterfly or whatever. I can't seem to find a longblock GSR motor anywhere...but I can find a B16A no problem
What setup would be better for turbo? I really want turbo...but part of me is thinking I should just go N/A...but maybe not.
but to some everything up...I want 2 liter. I DON'T want CRVtec. Tell me every single option their could be and the benefits and feasability of each.
Old Mar 2, 2003 | 09:33 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The stroke on the B16 isn't long enough to provide about 2.0 liters of displacement if you bore it out. Also, the B18 motors have a taller deck height than the B16 so you can't just pop a B18 crank into a B16 block. You would have to install a deck plate to do so.
Think about it this way. It's cheaper to buy a B18C block and resleeve/bore to 84 mm; than it is to buy a B16A block, B18C1 crank, deck plate, and resleeve/bore to 84 mm.
Old Mar 2, 2003 | 10:28 AM
-KangaRod-'s Avatar
-KangaRod-
Captain
I'd consider sleeving bigger than 84 mm. If you are going to sleeve it, why not make it 86 mm?
Old Mar 2, 2003 | 10:35 AM
incublinkus
JDM Fan Boy
thats for the B16 your talkin about...yeah...i am definately getting it sleeved...so couldn't I just bore a B16 to 86 mm? or is that just asking for trouble? it would still have the awesome rod/stroke of the B16, only 2 liters...how sweet would that be? any downsides?
Old Mar 2, 2003 | 12:24 PM
-KangaRod-'s Avatar
-KangaRod-
Captain
Well, that engine would have a super peaky powerband, even moreso that the that of the b16 right now. I wouldn't do it if you need midrange power, or if you want lots of torque cause you really wont feel the torque in that engine. I'd still say grab a GsR. Rod:stroke isn't about better or worse, its about what kind of power you want to make. The lower the rod:stroke the more torque you'll make, and the sooner it will come on. The higher the rod:stroke, the more revhappy your engine will be.
Old Mar 2, 2003 | 12:28 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
86mm sleeves don't leave much material around the sleeve, so structural integrity is an issue. TheN/A guys who sleeve their blocks usually don't go past 85.5mm or so, and the F/I guys usually go up to 84mm. If you're going turbo, stick to 84mm sleeves. Sleeving a B16A to 84mm yields about 1.7L of displacement. Sleeving a B18C to 84mm yields 1933cc of displacement. Sleeving a B18A/B to 84mm yields 1973cc of displacement. The B16B has the same deck height as the other B series blocks, so you could theoretically put an LS crank into one , run LS rods, and sleeve it to 84mm, which would be the equivalent of an LS/VTEC sleeved to 84mm, or a B20/VTEC. Whether you'd want to do that to a B16B block is entirely up to you. For simplicity, it'd probably be most reliable to just sleeve a B18C out to 84mm. You'll be closer to 1.9L than your goal of 2.0L. If you really need to be closer to 2.0L, then a properly built LS/VTEC should be fine. The best of both worlds(OEM VTEC components/reliability and longer stroke and a little more displacement) would be to take a B18C or B16B and run an LS crank, rather than trying to add VTEC oiling components to a B18A/B block. If you wind up running a non-VTEC block and adding the VTEC oiling components, you'll probably want to add a block girdle as well. You can either run an OEM GSR/ITR one or a Z10 one. With either of those, you'll have to have dowels properly machined into your mains to keep it properly alligned. Hybrid Garage has a new girdle out that includes dowels, covers all 5 mains, and looks very sturdy:
http://store.hybridgarage.com/pics/TeamHGR-girdle/
Retail Price $539.99
Introductory Offer $499.99 with FREE SHIPPING!
Wholesale/dealer inquiries are welcome!
02/05 -- We reduced the price to $389.99... read below
No drilling is required, everything is bolt-on, including dowels.
By the way, this only applies to B16A, B17A, B18A, B18B, B20B, and B20Z -- You will have to run a GSR oil pan and windage tray for clearance. You also need a GSR oil pickup.
Old Mar 2, 2003 | 12:48 PM
-KangaRod-'s Avatar
-KangaRod-
Captain
wow, thats nice. I just put my z10 one in though. I'm sort of even regretting buying that one though, I think i probably would've been fine without it.
Old Mar 2, 2003 | 07:28 PM
Speed Phreak's Avatar
Speed Phreak
Turbomafia
Why are you so up in arms about a B20/VTEC? It's not a bad engine if built CORRECTLY. If you build if 1/2 assed like most people do, then yea it'll be full of grimlins. It would turn as much or more power than any of the other engine's you've proposed. B20/VTEC's are nasty nasty engines if you build them right. Sleeving any of those engines and you're gonna be spending $1000 just to get the 84mm bore.
