obd1 vs obd2 b16
Old Jun 21, 2002 | 04:11 AM
madlow's Avatar
madlow
Default obd1 vs obd2 b16
i am lookin into swapping a b16 into my 94 civic sohc vtec. if i did the b16 obd1 (to save $1000) am i goin to run into any problems and is this the recomended swap?
Im just lookin for reasons why i should go one way or the other. thanks!
Old Jun 21, 2002 | 10:48 AM
v4lu3s's Avatar
v4lu3s
your car is obd1
it only makes sense to use the obd1 engine since it will cost less and be easier to install.
Old Jun 21, 2002 | 02:02 PM
KawiGreenVTEC's Avatar
KawiGreenVTEC
Default Re: obd1 vs obd2 b16
:headscratch:
Not sure what desicion you are trying to make:
94 Civic = OBD 1
and you want to use a OBD 1 B16, what's the problem???
Old Jun 23, 2002 | 06:00 AM
Outxider's Avatar
Outxider
X-Motoring
im runnin a 94 b16 in my 93 si. have a dinan chip ecu. runs very hard. late
Originally posted by v4lu3s
your car is obd1
Old Jul 10, 2002 | 04:16 PM
likaciv's Avatar
likaciv
Pretty Much its a Civic
what about the cable clutch issue vs. the hydraulic? My understanding is that the late model 89-91 b16 came with the cable clutch and can be found for around 1500 and the b16a3 and b16a2 the del sol and Si motors respectively, came with the hydraulic clutch and a steeper price tag. thats just my take
Old Mar 7, 2005 | 04:47 PM
RiverRider's Avatar
RiverRider
I am wondering the exact same thing, I have a 1994 Civic SI and I would rather put in the B16A1, can anybody give me the low down compared to the B16A2 Swap.
Old Mar 7, 2005 | 09:29 PM
alright the transmission shouldnt be a problem, there both hydraulic, OBD1 and OBD2 B16s are both hydraulic ( USDM side atleast, the B16s in the del sols were OBD1 and the 99-00 Sis were OBD2 )
I dont really get the question? it should be pretty obvious to drop the OBD1 in a OBD1 car.
theres really no point what so ever to put the the first gen b16s in your car, youd need to convert from hydraulic to cable, OBD issues, are just somethings that can go wrong. It would be a lot cheaper to just get the 92-95 B16s
Old Mar 8, 2005 | 01:11 PM
ohio_civic's Avatar
ohio_civic
Ok your talking about the b16a sir I thats odb0 you need the 92-95 sir II odb1 motor, this is also somethimes called a b16a2, but its actualy the second generation b16.
go HERE!!!
Old Mar 9, 2005 | 01:03 PM
likaciv's Avatar
likaciv
wow, this is from like 3 years ago!!
Old Mar 9, 2005 | 11:33 PM
holy shiat, i didnt notice h:
