Ultimate Turbo Setup
got another quick question .. i heard that if u run a intercooler w/ no bov that it was a very bad thing?? any truth to that?. is it not good to run an intercooler w/ out a bov.. or would it been fine?.. now i know that its bad to to have a bov period but i'm askin' intercooler w/ not bov.. for say a couple of weeks??
taylor
taylor
intercooler and bov are two separate functioning parts in teh turbo system.
a blow off valve or a bypass valve is there to prevent turbo damage caused by forced air hitting a closed throttle body, and bouncing back to reverse trhe spin of the turbo...at best it saves you from damage at worst it helps driveability.
your car is a light weight civic... (92-95 hatch or 96-98 coupe)
Originally posted by skratchnsnift
get the rex
get the rex
Myself, I think i'd buy a '03 Cobra. Can't beat near 375whp from the factory...
Originally posted by hyperlite
yes, but u have no "looks appeal"
But to each his own.
Besides, i've got a turbo AWD DSM that looks just fine.
Originally posted by MrFatBooty
I think that before you go off and drop 10 grand on a "project" (will you be doing the work on this thing?) you should figure out how all this stuff works.
taylor
do know how all this stuff works.. in regards to my question i asked ealier which obvisouly you couldn't answer.. i called a shop.. here is the answer i was lookin' for: boost goes from turbo to intake manifold and with no bov it goes back down from the intake manifold in to the turbo.. cause there is no bov.. stick on an intercooler then you have hot air going out the turbo through the intercooler and then you have cold air going into the intake manifold.. when you left off the gas now instead of hot air going back into the hot turbo.. you have cold air going into the hot turbo.. which will shock it, which is bad!!
A: They are dumbasses
B: You are the dumbass and they actually know what they're talking about. Though they didn't think you could wrap your brain around the concept of fluid dynamics, so they gave you the "lolly pop to shut you up" answer
In either case, don't be such an ass. The seperate thread you started that 1stgenCRX'r and I replied to you on gave you all the CORRECT info.
