GSR vs B16 injector specs
Old Feb 9, 2003 | 03:53 PM
drift's Avatar
drift
Flaccid Member
Originally posted by accordhybrid
Drift you are wrong the 92-96 prelude H22a1 injectors are 345cc peak and hold I have seen people that have had theres cleaned and the flow rate is 345cc
all the injectors i've personally flow tested are 310cc... between 300-320cc at 45psi.
Old Feb 10, 2003 | 11:15 AM
accordhybrid's Avatar
accordhybrid
We both may be right there is always a debate about the flow rate of these injectors
Old Feb 11, 2003 | 06:23 AM
v4lu3s's Avatar
v4lu3s
345cc at 100% duty cycle
310 is around 90% duty cycle
i picked up a set that was flow balanced by RC froma buddy that went turbo and went bigger....RC said 345cd. Hondata is, I believe the source of the 310cc, and I have been told they dont test at 100%...
Old Feb 11, 2003 | 08:40 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Running at 100% duty cycle is not recommended at all. On OEM-type injectors you shouldn't go past 80% duty cycle, with specialized pieces like RC's you can go up to about 90% safely.
Old Feb 11, 2003 | 08:55 AM
v4lu3s's Avatar
v4lu3s
im just pointing out that the injectors sizes are relevant to how they are measured. as far as i know all honda injector ratings are NORMALLY rated at 100%, but hondata rates at 80 or 90 percent....throwing figures around and calling each other wrong dont make much sense unless the flow rate is qualified.
and i agree that 100% flow rate in real use is a long way from safe or sane when looking for the limits of your engines out put.
