JRSCed TypeR hatchback!
Originally posted by redheat86
as everyone stated, not the best motor to use FI on, not the worst either. just a waste of money. there are much better options out there for the amount of money that a super charged b18c5 would cost. you could build a very nice n/a motor for that price and be running a set of itb's daily. in my opinion that would be glorious. mainly for the sound.
Originally posted by westcoaststyle
That's true too... but not many people are that anal about tuning... especially when you really don't know what compression ratios are.
Wow, you guys seemed to have it all figurued out, except one thing. Running higher boost wont make you faster if you have a higher compression ratio to start. These numbers arent accurate so don't complain, but heres an example. If you have a 10.6:1 compression ratio with a turbo on 10lbs you'd be pumping out the equivalent of a 10.1:1 with 12lbs of boost. The advantage to starting with a higher compression ratio means you can run your turbo at lower boost, or have a quicker spooling turbo, in effect making your car faster. Also, C5's, expensive as they are (and yes I agree, they are a waste) can be turbo'd safely, just tune it. But, I would hope anyone spending the amount of money required to install a C5 into a hatch and then turbo it would also spend the extra money with a Hondata (stage 3??) and a knowledgable man on a dyno making it run right.
if you dont believe me then look at the pro's that run big ass turbos. they run the big turbos with bigger boost cause on the high end bigger boost is better.
Higher boost is required when you have lower compression. Let me find the equations... but the theory is that boost adds to the compression ratio, so starting with a high compression you will need less boost to achieve the same horse power.
Think about it logically, if you add 10lbs of boost you are only adding more air to the mixture therefore giving you a higher compression, that is why you can run lower boost on a higher compression, assuming you do the math right it is possible to achieve the same numbers from low boost high compression and high boost low compression setup.
Shiat!!!
Simple...what make more power???
B18B 9.2 cr 8lbs
B16A 10.2 cr 8lbs
B18C 10.0 cr 8lbs
B18C5 10.6 cr 8lbs
The damn B18C5! Why, because compression = power, the given-all engines used the same turbo setup and the max amount of dyno tuning needed to extract potential. Point is, a B18C5 in stock for w/ a damn turbo will make more power w/ the proper tuning and fuel than any of it's siblings, pound for pound it will make more power due to the higher compression. That **** can have 12-1 as long as it's tuned, a/f checks in and the fuels there.
This is like beating a dead horse. Is it worth is-no, can it be done-yes, lots of hp-yes, AFTER A LOT OF TUNING,should I do it-no, I'd rather boost a damn LS engine or a B16A than ever spend ALL that $$$ on a C5 and then HAVE to fork of all the extra $$$ to make it run correctly.
B18B 9.2 cr 8lbs
B16A 10.2 cr 8lbs
B18C 10.0 cr 8lbs
B18C5 10.6 cr 8lbs
Originally posted by SiR-DC2
Shiat!!!
B18B 9.2 cr 8lbs
B16A 10.2 cr 8lbs
B18C 10.0 cr 8lbs
B18C5 10.6 cr 8lbs
Shiat!!!
B18B 9.2 cr 8lbs
B16A 10.2 cr 8lbs
B18C 10.0 cr 8lbs
B18C5 10.6 cr 8lbs
b16's boosted compression ratio: 15.2
b18b's boosted compression ratio: 13.6
b18c's boosted compression ratio: 14.8
b18c5's boosted compression ratio: 15.8
At 12 psi:
b18b's boosted compression ratio: 15.8
What's stopping the b18b from running 12 pounds of boost? Nothing. That will leave it will the exact same boosted compression ratio (though the b18c5 will have a lower dynamic compression ratio), at which point it will experience exactly the same stresses on the engine. AND the b18b has more displacement, will require less tuning, and less fuel at idle and low revs.
Price difference between b18c5 and b18b: $3000+
Price difference between turbo designed for 8 psi and 12 psi on a b18: $0.
The point being, as luti said previously, for any application you can run either A) high boost and low static compression or B) low boost and high static compression with exactly the same effects.
