b18c headgasket timing adjustment
Old Jan 29, 2003 | 03:37 PM
CivOnDubs's Avatar
CivOnDubs
Default b18c headgasket timing adjustment
I just got a spoon headgasket for my JDM B18c motor. Since the motor is now sitting 0.3 lower to the block the timing belt is going to have some extra slack in it. What can I do to time the motor properly with this new thinner headgasket in.
I just got ARP head studs too, any tricks to putting this all back together? Thanks in advance!
Old Jan 29, 2003 | 06:22 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I don't see you needing to do anything differently with the thinner h/g. Just be sure that you have a good tensioner and you have the belt on correctly.
As for the studs, just be sure to use some antisieze lube and torque them correctly. I have ARP head studs and I just followed the instructions that came with them... simple.
Old Jan 30, 2003 | 04:19 AM
JimBlake's Avatar
JimBlake
Default Re: b18c headgasket timing adjustment
As the tensioner takes up the slack in the belt, your cam timing will be retarded a bit. If its too far off for your taste, you gotta get adjustable cam gears.
Old Jan 30, 2003 | 08:35 AM
dubcac's Avatar
dubcac
I
I don't think it's enough of a difference to worry about the timing.
Old Jan 30, 2003 | 01:04 PM
sunshine's Avatar
sunshine
Torqueless Wonder
Agreed. I think for every .010 you take off the cams get retarded like a degree, and you're no where near that with a headgasket. So I think you're safe. If you get mill happy, that's another bag right there.
