Turbo trim Q's
T3/T04E, As in what specs? I got a guy who wants to sell his T3/T4 turbo, Im not sure what he wants for it but if its a resonable price should I buy it and then up/down grade it to X specs?
This should be decent:
http://store.yahoo.com/cheapturbo/gart3to457tr.html
Or, you might want to get a 50 trim for better spoolup.
Originally posted by seth90dx
would this be a good turbo for the ZC? COMPRESSOR SPECS:T04S
.70 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
HIGH FLOW 76 TRIM WHEEL
.70 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
If you want to run a T4 compressor, I would run a T3/T04E, .48 turbine and .60 compressor and either 50 or 57 trim. That should be more than enough to suit your needs now, and when you're ready to increas your boost level, yet still retain a decent spoolup.
Sorry to bring this one back from the dead dude... I realy apriciate the help your givin me but what the hell does A/R mean?
Would this one be good?
COMPRESSOR SPECS:
.60 A/R HOUSING
57 TRIM WHEEL
TURBINE SPECS:
.48 A/R HOUSING
STAGE 3 WHEEL
CHRA comes standard with 270 degree thrust bearing, 360 degree thrust upgrade option below
oil lubricated centersection. water cooling option below. for use with external wastegate, internally wastegated option below.
COMPRESSOR SPECS:
.60 A/R HOUSING
57 TRIM WHEEL
TURBINE SPECS:
.48 A/R HOUSING
STAGE 3 WHEEL
A/R is the area/radius ratio of a turbine or compressor.
Are those specs from a T3/T04E? If so, that should be fine, but I believe you can get them with the same specs, but with a 50 trim compressor wheel, which would spool a little quicker.
