Adjustments For Ctr Pistons In Itr Block
Old Dec 19, 2002 | 08:44 PM
RedUSDM'97TypeR's Avatar
RedUSDM'97TypeR
Default Adjustments For Ctr Pistons In Itr Block
WHAT TYPE, IF ANY, OF ADJUSTMENTS DO I HAVE TO MAKE WHEN I PLACE CTR PISTONS IN AN ITR BLOCK/B16 HEAD? I HAVE SKUNK2 STAGE I CAMSHAFTS. WILL I HAVE A VALVE LASH PROBLEM? IF SO WHAT CLEARANCE SOULD I ADJUST THE VALVES AT? WILL I NEED TO MODIFY THE BLOCK IN ANY WAY? ANY OTHER TECH SUGGESTIONS WOULD BE HELPFUL. THANKS GUYS.:thumbup:
Old Dec 19, 2002 | 08:51 PM
qtiger's Avatar
qtiger
You will need to adjust your caps lock to the off position for your pistons to fit.
Old Dec 30, 2002 | 11:08 PM
sunshine's Avatar
sunshine
Torqueless Wonder
HAHAHHAHAHAHAHAHAAHAH
Old Dec 31, 2002 | 07:14 AM
ferrealb16's Avatar
ferrealb16
you are going to have to machine either the rod or piston because the ctr rods are thinner if i remember correctly. but have you considered going with a floating piston? xtra 5 hp.
