building a "stock" lsvtec.. ?
Old Dec 18, 2002 | 12:52 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Originally posted by dubster99
Most problems come from the Stock LS rod bolts not lasting long at 8k...they weren't designed to go that high, so get some ARP studs and you'll be ok to 8k.
Studs hold your head on. You want new rod bolts. Which I'm sure is what you meant to type anyway.
Old Dec 18, 2002 | 01:50 PM
dubcac's Avatar
dubcac
I
Yeah that's what I meant to say, I had rod bolts in there too lol. Anyways if you want a good lsvtec site check out
http://www.c-speedracing.com/howto/lsvtec/lsvtec.php
This one is for a b20vtec and is a newer article, but it's the same principles as an lsvtec.
http://www.c-speedracing.com/howto/b20vtec/b20vtec.php
Old Dec 19, 2002 | 07:51 AM
madlow's Avatar
madlow
Default another question..
will the b16 or b18c head line up PERFECTLY to the b18b block? I saw in one set of directions that they relocated a dowel on a b18a. Does this have to happen on the b18b block or the vtec head?
Old Dec 19, 2002 | 10:40 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You relocate 2 dowels on the head.
Old Dec 19, 2002 | 11:44 AM
madlow's Avatar
madlow
Thanks for your help! I just wanted to confirm the directions that I have.
Old Dec 19, 2002 | 12:41 PM
dubcac's Avatar
dubcac
I
You do know about the oil feed correct? It's explained in the links above.
Old Dec 20, 2002 | 04:18 AM
madlow's Avatar
madlow
yep I knew that from the start.. I just wasn't sure exactly what needs to be done at a machine shop, but since the new holes have to be drilled in the head it makes it easier.
