turbo 94 integra gsr radiator question
Old Nov 30, 2002 | 08:59 PM
adame's Avatar
adame
Default turbo 94 integra gsr radiator question
A friend of mine just installed a drag 3 kit on his gsr. After installing it his radiator started leaking and got worse. He replaced with another stock from another gsr and now has the same problem 3 days later.
Any help??
Old Nov 30, 2002 | 10:06 PM
dubcac's Avatar
dubcac
I
Is the radiator itself leaking, or is it a hose? Check the o ring where the drain plug is.
Old Dec 1, 2002 | 08:17 AM
adame's Avatar
adame
the radiator itself has sprung a leak, we can see it.
Any reason after adding a turbo this should happen?
Old Dec 1, 2002 | 02:48 PM
qtiger's Avatar
qtiger
If you have a leaky headgasket boost could creep into your cooling system, but that would just bubble the coolant and escape through the overflow bottle. (Seen it happen)
Where is the leak? I'm guessing someone just wacked it good during the installation.
Old Dec 1, 2002 | 03:07 PM
adame's Avatar
adame
I will have to get exact location.
This is the 2nd radiator put in that is leaking now, so I dont think someone damaged both putting them in.
Old Dec 2, 2002 | 06:08 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
If the motor mounts are bad, when you rev it, it could be rocking the manifold/turbo/etc into the radiator...
