Throttle Body Compatability??
Old Dec 10, 2002 | 07:52 PM
spooncivicb16b's Avatar
spooncivicb16b
like i said i got the throttle body for free. i plan to put it on when i get a skunk 2 intake manifold. also im going to a 4-1 header power core race cat and tanabe super racing medalion exhaust. this is all after christmas though i have to buy presents. so january
Old Dec 11, 2002 | 11:45 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Originally posted by inspyral
I'm running a GSR tb
chris... which year of the GSR TB u running on ur civic?
Old Dec 12, 2002 | 07:30 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
98 - OBD-II
Old Dec 12, 2002 | 08:08 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
This is the TWM B-series ITB kit:
Observe the complete manifold, tb's etc. The intake manifold flanges on B- and D-series motors are different.
However, TWM also makes manifolds to bolt a pair of Weber DCOE carbs to a D-series motor. Like this (thanks for the pic Harry):
Now, you don't want to run carbs on a fuel injected car. Well you could but anyway. TWM also makes two-barrell throttle bodies that are shaped just like DCOE carbs.
So, you want ITBs on a D-series you need a DCOE-style manifold and a pair of TWM fakemeout DCOE throttles.
Old Dec 12, 2002 | 10:15 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
what's the benefit of installing this TB? would it even be smog legal? and how much more WHP we talking about here with this carb bolted on?
Old Dec 12, 2002 | 10:28 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
It's not a carb, it's an ITB setup but a bit more creatively assembled. Smog legality depends on your jurisdiction. It can add like 30-40 whp but you need a new programmable ECU like an AEM, Haltech, TEC III, etc. Hondata won't work.
The injection hardware will run you like $2300 plus another $1000 minimum for the ECU. No, it's not cheap.
I was answering the question of if you can get ITBs on a D-series, not if it's worth the money.
Old Dec 12, 2002 | 10:45 AM
qtiger's Avatar
qtiger
Hondata WILL work IF you get a map sensor working properly.
Old Dec 12, 2002 | 01:23 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
It looks like that little black thing int he lower pic is supposed to be a MAP sensor. So, would you need to have one on each TB and average the signal or something?
Old Dec 12, 2002 | 02:08 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
At least on the actual ITB kits there's a vacuum nipple on each runner. You have to fab up an equalization chamber and then run one MAP sensor off the chamber.
Old Dec 12, 2002 | 03:27 PM
qtiger's Avatar
qtiger
That would be a TPS.
