swap/conversion is almost done...
Old Nov 19, 2002 | 08:10 AM
HeavyCivic's Avatar
HeavyCivic
Team HighRev
Default swap/conversion is almost done...
hey guys as some of u might know im gettin a b18 swapped into the HeavyCivic and having it converted to stick
everything is going fine so far
motor dropped in easily enuf, pedals are in, wiring is done
i have no power steering until i buy a new pump but thats not that big a deal
i have come across one small problem...the gsr headers i got dont reach the cat
there's about a 7" gap from the downpipe to the cat
i either have to get my headers extended or i have to find the right kind of headers to use
im sure someone has seen a 99 4dr with a b18 swapped into it
so can anyone tell me what headers to use? 99 SI? LS?
otherwise im stuck extending my gsr headers which is fine but i would rather get the right headers.
any help is appreciated
Old Nov 19, 2002 | 08:05 PM
Guest
Guest
Posts: n/a
we had to weld a chunk of pipe in for my swap too. dont trip, it will be fine. just measure correctly.
cheers
Old Nov 19, 2002 | 10:00 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
If you don't want to permanently alter the header you can make an extension to bolt in between the header and cat.
Old Nov 20, 2002 | 03:07 PM
SmOkIneLf's Avatar
SmOkIneLf
ye ajust bolt in an extension sounds like the easiest way
Old Nov 21, 2002 | 02:39 PM
SmOkIneLf's Avatar
SmOkIneLf
oh and good luck with the swap hope everything goes well :thumbup:
