Denso Iridiums quick Q
Old Nov 8, 2002 | 02:19 PM
TwilightX's Avatar
TwilightX
Default Denso Iridiums quick Q
I'm thinking of getting a set of ik22 Denso Iridiums for my 97 DX - do you think I'll be running too cold or will it be fine? I have a set of Bosch Platinums in right now and I heard they're crap...any suggestions? Thanks!
T-X
Old Nov 8, 2002 | 02:24 PM
dubcac's Avatar
dubcac
I
NGk Copper, the best conductor.
Old Nov 8, 2002 | 02:48 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I feel platinum and irridium plugs are a waste of money, when NGK coppers work so well. Plus, you could buy like at least 5 or 6 sets of NGK coppers for the price of one set of irridium plugs.
Old Nov 8, 2002 | 02:55 PM
TwilightX's Avatar
TwilightX
Well, I mean there won't be a problem with them though right? A friend of mine said they're 2 ranges colder than I need. He recommend IK16's because the engine needs to get hot for the carbon deposits to burn off of the spark plugs or something...
Old Nov 8, 2002 | 03:20 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Why are you running two heat ranges colder? Unless you're running FI, there's no reason to run a colder plug.
Old Nov 8, 2002 | 04:00 PM
TwilightX's Avatar
TwilightX
I figured they'd be better than the Bosch Plats - I'm upgrading little by little, so I figured if I get a really good price on them I'd get them...I'm getting 4 for like 15.00...
Old Nov 8, 2002 | 07:21 PM
taylormadem5's Avatar
taylormadem5
Use Factory Plugs, they work great. Denso Iridum plugs SUCK, they are a waste of $$$. Unless your running FI use a plug that is of equal or quality as the stock ones are. Hondas Electiral system is perfectly fine unless your running FI, or have a seriously built motor.
Old Nov 8, 2002 | 09:54 PM
dubcac's Avatar
dubcac
I
NGK coppers, stock heat range...hands down.
Old Nov 10, 2002 | 01:07 PM
-KangaRod-'s Avatar
-KangaRod-
Captain
is there any advantages to running hotter than the stock range?
Old Nov 12, 2002 | 05:16 AM
jeems's Avatar
jeems
i be slow
i always heard that the densos were pretty good! they are expensive though.
