Engine rebuild kits???
Old Oct 28, 2002 | 05:08 AM
poolboy's Avatar
poolboy
Default Engine rebuild kits???
I've been searchine online everywhere and I've found a rebuild kits for just about every honda engine ever made except for the b-series and h-series engines and although I found a rebuild kit for Y-21 tranny I still need a rebuild kit for my b16 because I really don't have the time to go out and buy all these things individually...................help
Old Oct 28, 2002 | 06:45 AM
-KangaRod-'s Avatar
-KangaRod-
Captain
Where did you find these rebuild kits?
Old Oct 28, 2002 | 08:32 AM
poolboy's Avatar
poolboy
http://www.rpmrons.com/Topline.html
Old Oct 28, 2002 | 08:36 AM
poolboy's Avatar
poolboy
http://www.drivetrain.com/hondamaualtransmission.html
this is the tranny site.............
damn I'm having a really crappy time trying to make posts......
but any help with the engine kits would be the shiiiiiiaaaaT!!
Old Oct 28, 2002 | 07:16 PM
taylormadem5's Avatar
taylormadem5
Go to http://www.inlinefour.com/spoon18lstro.html, its a complete rebuild kit, Inline Four offers B16B owners a chance to stroke their existing 77.4mm stroke to a 87.2mm utilizing the Spoon 1.8L stroker kit. The bore is kept at 81.0mm, but is also offered in 81.25mm for oversized applications. Compression level is set at 11.3:1 with this kit. Kit consists of crankshaft, pistons w/ wristpins, piston rings, connecting rods and a 2ply. Spoon metal headgasket. SPECIAL ORDER ITEM. that should help a little. Its like $1180 for the whole kit but includes basicly everything you need
Old Oct 28, 2002 | 07:20 PM
taylormadem5
ohh, also i would suggest using ARP head studs and ARP rod bolts when rebuilding the engine. It will help with keeping the engine together if your planning on taking it over 9000rpms. and the head studs are reusable where as the HONDA ones are torque to yield meaning they are good for one time only
Old Oct 28, 2002 | 10:18 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
That is not a rebuild kit, that is a stroker kit.
The best option is to go to a Honda dealer and ask for all the parts needed to rebuild a B16. Say you need the list and you'll "think about it" as far as buying everything. If they ask for a specific model/year there's the del Sol VTEC or '99-'00 Si. Honda sells gasket kits for the entire motor but as far as pistons, rods, bearings etc you'll have to purchase those individually. But yeah, a Honda dealer will be able to get you a nice parts list going even if it isn't really a "kit."
