labor?
Old Oct 27, 2002 | 09:04 PM
crash's Avatar
crash
Default labor?
Can any one please tell me how much it would cost to get my vavles replaced, just the labor, i have a 95 gsr.
thanx
Old Oct 27, 2002 | 10:04 PM
qtiger's Avatar
qtiger
Depends. If you take the head off yourself, $200 or so, including hot tank & whatnot.
If you just take it in... no less than $700.
Old Oct 28, 2002 | 01:46 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
My friend had his valve springs replaced and they charged him $300 and they pulled the heads off themselves.
Old Oct 28, 2002 | 06:28 AM
TheRooster's Avatar
TheRooster
Former Senior Member
You don't have to pull the head to do valve springs. Your friend got screwed. <edit> Unless you mean your friend pulled the head himself, in which case, he could have just left it on there. </edit>
Replacing the valves is pretty easy (you will need a valve spring compressor though) and if you've got the knowhow to take the head off, you might as well do the rest.
Old Oct 28, 2002 | 10:33 PM
sunshine's Avatar
sunshine
Torqueless Wonder
The parts arn't that expensive, if you decide to rebuild your head yourself. Honda valves are like 20 bucks each. If memory serves me it's like 18 exhuast, 22-23 intake. Valve seals are like a buck each, valve guides come in at a few bucks as well. Ooops but since you asking for labor... going rate for labor is generally 70 bucks an hour, depending on the job. Typical rebuild time is about 1.5-2 hours if your head is already clean and you know what you're doing.
