Vaccum leak problem?
Old Jan 3, 2008 | 07:08 AM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Default Vaccum leak problem?
I have just put a n/a built engine (b16a2) into my eg6 civic after having a turboed build in it.
I have started it and it runs however the idle seems to be 'hunting' a bit.
The engine management light stays on i havent read the code yet tbh but
im sure its a vaccun leak problem as i cant remember were all the vaccum leads go to and some are missing.
Can someone show me were they are meant to go with a few pics or illustrations?
Old Jan 5, 2008 | 08:35 AM
gsreg94's Avatar
gsreg94
Old Jan 5, 2008 | 08:36 AM
gsreg94's Avatar
gsreg94
http://shopkey5.com/mric/common/asp/...CO.%2C%20INC.&
i found this i dont know if it'll help let me know if u need more
Old Jan 7, 2008 | 11:30 AM
B16a2VTIguy
Built B16a
Thanks, checked all the vacuum hoses today and all are in the right places as far as i can see.
I checked the cel codes and the following came up....
7 - TPS
14 - Idle control
41 - Oxygen sensor heater circuit
i unplugged these when the engine was running to see which one would make a differance if any.
I have unplugged the ecu fuse to reset the ecu, so i can see what the 'real' fault is.
How long do i have to leave it to 'forget'?
Old Jan 7, 2008 | 01:03 PM
gsreg94's Avatar
gsreg94
30 seconds for an ecu reset. those the sensors are twired in together. possible a bad 02
Old Jan 7, 2008 | 01:04 PM
gsreg94's Avatar
gsreg94
if u had a turbo runing in it before it me caked and baked up.. not sure
Old Jan 7, 2008 | 01:10 PM
B16a2VTIguy
Built B16a
thats makes sense actually, as thats the only thing i didnt unplug to test.
I also tryed resetting the ecu, and all 3x faults still come up (7,14,41)
Thanks again, ste
Old Jan 7, 2008 | 03:53 PM
gsreg94's Avatar
gsreg94
i have a tubo b18c in my eg hatch before i bought it. and it was taken out of a 99 ek so when they switch it in to the hatch the had to convert it from a one wire to a 4 wire and they were on a little herb if u wat i mean. and the half assed and the three sensors act up so i get code 7 every two weeks or so. so iam right there with u. my next step is ordering a custom full engine and ecu harness from rywire.com and chase bays take a look bud.
Old Jan 10, 2008 | 03:28 AM
B16a2VTIguy
Built B16a
I am going to try replacing the oxy sensor today, and ill strip the idle control and clean it out.
Old Jan 10, 2008 | 06:34 AM
B16a2VTIguy
Built B16a
Just cleaned the idle control valve, and it made no differance,
But when i unplug the idle control valve the engine cuts out, however if i unplug the o2 sensor it makes no differance to the way it runs.
Is a D16z6 and B16a2 o2 sensor the same?
