how high can you rev a b16 with..
Old Oct 19, 2002 | 05:37 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Originally posted by taylormadem5
the cams that are in it are "good up to 9000 rpms" according to Spoon
Honestly, Spoon cams are pretty lame. Besides, rather than go by what you heard from a buddy about what RPM the cams peak at, get the car on a dyno and find out for real.
Old Oct 19, 2002 | 08:12 PM
taylormadem5's Avatar
taylormadem5
spoon cams are lame..thats a first..im not going by what a "buddy" of mine told me..im going off several websites..including Spoons own site..the car hasnt been on the dyno yet..because there are still some things that need to be fixed and or corrected before wasting $$ on a dyno...i have never heard of a single product from Spoon being "lame" or not worth the money...but maybe you can write Spoon and express your views seeing how you seem to know so much about them...lol..thanks for all the input
Old Oct 19, 2002 | 08:59 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Most Spoon stuff is overpriced and easily outperformed by more inexpensive offerings. $1200 for an LSD when a Kaaz can be had for $800? How bout $550 for a 70mm throttle when you can get one from Erick's Racing for $400? $1800 for a pair of freakin brake calipers?!
Aside from any value judgements on the overall brand, you've misread the product description in detemining that these cams make power up to 9000 RPM. To quote:
"Factory B16A/B18C1 valve springs cam handle up to 8,300rpm, while the use of aftermarket springs can handle revs in excess of 9,000rpm."
This does NOT mean that the power peak of a motor using these cams will be at 9000 RPM. It means that aftermarket valve springs are capable of being revved to 9000 with the amount of valve lift created by these cams.
Bottom line, put it on the dyno and figure out where the power peaks.
Oh, and about the original question of getting this chip...don't bother. Have something reprogrammed by Locash Racing where you know what exactly is being modified, instead of some eBay special that's probably some kinda pirated wannabe-Mugen program that disregards things like sensors and error codes.
Old Oct 20, 2002 | 11:37 AM
qtiger's Avatar
qtiger
Nuff said.
Old Oct 20, 2002 | 11:58 AM
-KangaRod-'s Avatar
-KangaRod-
Captain
:jawdrop:
Old Oct 20, 2002 | 03:03 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Originally posted by flySI
accordhybrid- Ummmm, the b16a has a very good bottom end. It comes from the factory pretty well balanced and is the only production engine that I can think of that has a near perfect rod-stroke ratio. Perfect R/S ratio is 1.75:1 and the b16a is a 1.74:1 so you see in stock form the bottom end is capable of around 9000 rpms safely IMO. Anything over that and I would have to agree that the rods will need at the least a bolt upgrade.
R/S ratio is nothing more than a fall-out number, has nothing to do with engine stresses, only the amount of friction that will be developed between the piston and the cylinder. As long as the rod isn't so short that the crank tries to push it through the cylinder at anything over 1000 RPM, you should be fine.
All in all, R/S ratio is a nice figure to keep track of, but isn't something to worry about. It is not a measure of potential power development, nor is it an absolute measure of how much stress the rod will see, it is just a ratio someone figured out you can get by measuring two items in the engine's structure.
For revability of an engine, the more important items to look at in the lower end are rod bolt strengths, tensile and compression strength of the rods, weight and peak speed of the pistons, and THEN look at the casting strength of the pistons along with the R/S ratio. By the time you really need to worry about that last bit though, chances are you will be floating valves too much to rev much higher anyways...
-Harry
AIM: NDcissive
Old Oct 20, 2002 | 03:47 PM
SmOkIneLf's Avatar
SmOkIneLf
can't a b16a rev up to around 9300 rpm's?
Old Oct 21, 2002 | 12:53 PM
flySI's Avatar
flySI
I didnt mean that the R/S ratio has a big role in the revability of the engine. It does have a roll though, the lower R/S ratio of the GSR and ITR is why honda gave them block girdles from the factory. R/S ratio does contribute to the overall stability of an engine at high revs. It is a small and no doubt negligible point, but it does contribute in a small way. The well balanced nature of the b16 is what really makes it a good candidate for high revs. I was merely using it as a way to show how well the engine was designed in factory form.
Old Oct 21, 2002 | 07:35 PM
taylormadem5
well..no worries about reving the engine anymore...the car is probably gonna be totalled after he hit a car that pulled in front of him...the radiator now sits below the hood support..that now rests on the valve cover...which is sitting with the engine in a not so straight position in the engine bay....and..the fenders, hood and bumper are no longer recognizeable... gawd damn idiot drivers...well thanks for all the info..a new project...mostlikely an ITR build up is in the works...hehe
Old Oct 22, 2002 | 01:11 AM
aut0tek's Avatar
aut0tek
LOL... I have. *cough* Oil filler cap $40.80 *cough*
