car is going through oil like no tomorrow
Old Oct 12, 2002 | 03:02 PM
taylormadem5's Avatar
taylormadem5
Default car is going through oil like no tomorrow
ok...when accelerating hard, black smoke comes our the exhaust, it goes through a quart a week or so...new valve seals and rear main seal where just put in..new head gasket was too about 10k ago....im thinking bad rings, and that they need to be replaced....anyother ideas where it could be coming from
Old Oct 12, 2002 | 03:11 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I thought black smoke = running rich?
Anyway, have you done a compression test?
Old Oct 12, 2002 | 03:22 PM
dubcac's Avatar
dubcac
I
I thought black smoke was running rich also, and burning oil is a bluish/whitish smoke. Anyways do a compression test and leakdown test.
Old Oct 12, 2002 | 03:28 PM
taylormadem5
yeah...had a compression test done when the swap was done, it read 190 on 1 and 3, and 180 on 2 and 4
Old Oct 12, 2002 | 03:31 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Have you done a copression test since it's started burning oil? See if any of your numbers have changed.
Old Oct 12, 2002 | 03:36 PM
taylormadem5
nope..but what should they read...keep in mind im at 5600ft above sea level...so it may be a little less...
Old Oct 12, 2002 | 07:05 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Your initial numbers are fine. I'm guessing if your rings are gone, your compression numbers will be lower now.
