Torn between supercharging or all motor with my jdm itr...
Old Jun 14, 2007 | 08:15 PM
natedawg421's Avatar
natedawg421
Default Torn between supercharging or all motor with my jdm itr...
What up guys.. I have a del sol with a jdm itr. I've been thinking for a while now and I'm kinda stuck on what route to take. I was thinking about buying a sleeved ls block and a Jackson Racing supercharger. I have always thought an itr should stay all motor though. I'm a torque freak and that's why I was thinkin about supercharging but like I said I am torn. Another option would be building a b20 block and throwin my head on it. Obviously money doesn't come into play too much but I would like to keep it under 3 g's if possible if I'm keepin her all motor. I'd be happy if I got close to 250 to the wheels. I guess I'm askin what a practical setup would be given what I mentioned? My mod list right now consists ofassword jdm intake,jdm header, im,tb, full 2.5 catback with no cat but two resonators.( I will be losing those soon) Buddy club cam gears,chipped ecu, and a competition clutch and lightened flywheel. I'm runnin 176 to the wheels and I think 123 ft. lbs. of torque. Any suggestions would be appreciated
Old Jun 14, 2007 | 10:56 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Why would you sleeve a block to make puny horsepower on a JRSC? You can slap a JRSC on a stock engine and make the numbers you are looking for.
Old Jun 15, 2007 | 08:55 AM
KrazyAboutHondas's Avatar
KrazyAboutHondas
all motor or nothing
nitrous oxide
Old Jun 15, 2007 | 08:58 AM
KrazyAboutHondas
personally, I would go for a lower compression setup, with a JRSC. lower compression on motor = more boost on JRSC
Old Jun 15, 2007 | 02:23 PM
Snoopy's Avatar
Snoopy
been there done that
if you're considering boost go turbo. you can make 250whp+ on a stock b18c easily
Old Jun 16, 2007 | 05:18 PM
steveT1's Avatar
steveT1
Default turbo is the way to go !
turbo is better than all your options , you can dial up or down boost and if you dont run boost its like all motor!
Old Jun 18, 2007 | 06:31 AM
lkailburn's Avatar
lkailburn
college kid
boost ftw.
turbo setups are relatively cheap and very scalable.
-Luke
Old Jun 18, 2007 | 04:22 PM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
HMMM most people with JRs are going with high compression. Its not like your going to be running 16 pounds on a JR, low boost high compression(or stock with a ITR)= damn good numbers check out the ever increasing JRSC thread on H-T for some good examples of your setup with a JRSC.
